Mirror Glitch and misc. issues
MR650
Michael
Hillsborough,ca
2021 F-150 Platinum Blk/Blk
I searched this forum and didn’t anything quickly on this topic so I’ll ask here and apologize in advance for mixing in a few other issues. If there are pointers to other threads please let me know and I’ll follow up there but I’ve had a number of issues with my 2021 F150 Platinum Super Crew. It’s the hybrid power boost model; purchased new. I take care of the truck but it has some issues that are annoying:
1) mirror glitch - periodically and not predictably when I get in and start the vehicle the passenger side mirror starts to move on its own snapping a few centimeters back and forth making a clunking sound like it’s trying and failing to adjust itself. No idea why it does this. It last about 10 seconds clunking back and forth. I’ve tried to catch it on video to show someone but by the time I get the phone ready it stops. Something is wrong with it. Truck has 30k miles on it.
2) static from the headrest speakers. I’ve posted Or replied to posts on this topic before. My Bay Area dealership did something inside the seat that made the static noises stop but it still intermittently will have some static from the headrest speakers that is annoying but not reproducible.. when it first happens I could reproduce it by pushing on the seat back but now it happens randomly and faintly and it’s really annoying.
3. the fuel door release mechanism just fell out yesterday, it’s a plastic stalk that is spring loaded with a rubber jacket inside the fuel door. It fell out and I put it back together but it makes a weird noise now so I’ll need to take that in too when I go for service next week.
4. there is a rattle someplace in the dash up high maybe behind the navigation/display console it might be some plastic trim around the console but I had similar issues with my 2017 raptor and it’s hugely annoying. I press on the dash in different places trying to get it to stop but only occasionally have success. Another hard to reproduce issue that is a quality problem. Same issue with my raptor not sure where the noise is coming from.
5. the rear passenger door sensor frequently but intermittently indicates the door is ajar when it isn’t. No amount of door slamming will make this go away. Then randomly it might turn itself off only to re-appear later. It’s usually the one rear passenger door but sometimes it has been other doors. The car is clean and the doors are shut but these sensors fail or give false negative readings. It’s really annoying because it sets alarms off inside and when you try to lock the car and walk away it causes the running boards not to retract and the lights to remain on. In Tahoe snow last month it did this for 3 days and snow builds up on the automated running board and then eventually when they do try to retract they Jane and the snow/grit will scratch your trucks finish as the running boards retract and push accumulated ice and gravel against the paint finish.. all caused by this faulty sensor.
all vehicles have issues but what annoys me most about this one is the large number of intermittent/hard to reproduce issues that require a lot of time to sort out. Seems to me like something is not right or reliable with the sensors/wiring on this vehicle.s
MR650
Michael
Hillsborough,ca
it goes back in on Tuesday.
The dealer is good and that works fine for issues like the fuel door. These other items are intermittent and don’t always reproduce on demand.
Sucks to have such electrical issues. You need a really competent tech willing to put the time into finding the issue. Unfortunately the pay structure penalizes such things. They want loads of billable hours that didn't take hours to achieve.
To find rattles, bang on it. The mirror sounds like a preset / memory issue, though it could be a pot in the mirror. They're not going to spend any more time on it than they can bill for, and ford won't allow something to be fixed that they can't duplicate because their stuff would never randomly act up....
tbinmd
22 KR F150
My 13gn and 12gen both would do that with the passenger mirror. I would just tap the mirror adjuster button and it would stop. It does eventually stop trying to seek, but it is annoying when it does it.
True North
Wyoming
2025 f-150 Lariat
Ah, the good old 2021 model. Wish you luck my friend.
MJG44
Toronto
I have nearly 20k on my 22 and pretty much since new I've had intermittent power on my interior 110v outlets. Yellow light kicks in and out at its own discretion. Bothered me for awhile as I used it for my android fastcharger but now I just plug into the USB C. I've checked for loose fuses but no luck.
Just such a hassle to bring the truck in and wait a day or more for them to resolve.
My 22 Expedition already had the master brake cylinder failure at 4k and the other day had zero power to my driver door accessories, then operated fine hours later.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
Would you do forum members a favor and add a signature that reads..
"Ford Motor Company PR: We pretend to care"
MR650
Michael
Hillsborough,ca
Hilarious
dannggg
Dang Le
Los Angeles, CA
Website
www.linkedin.com
2025 F150 Raptor
SWE @ Lockheed Martin
I fixed this today. Learned it while I did the factor 360 cam install. Your mirror looks like it’s clipped on correctly. But it’s not. Take it out put it back in again. U could hear one click and think it’s secured but it’s not. Put your palm at the center. Press a letter hard there should be another click. After I did this it was fixed! It stopped clicking around every time I adjust the seats.
Ricksc
Rick
Bay area
Have you tried to manually unfold the mirror then hit the open button to let it reset its self? You can do either fold or unfold to get a reset position. Mine did this a few times. I also went in and turn power fold function off and back on that was what finally fixed it.
