Lowered with Timbren
MJG44
Toronto
Anyone who has a flip kit use the Timbren?
Not interested in air bags. Would consider installing Timbren for when I occasionally load the bed.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
Really don’t think you will have the clearance for the Timbren set.
How much clearance do you have between axle tube and bottom of bumpstop
PowerBoostSoCal
San Diego, CA
2025 Lariat EB, 2023 Lariat EB & 2021 F150 Lariat PB
I tried these on my 2021 F150, regretted the installation within five minutes. Basically you now have these bumpstops about 1 inch from the axle as opposed to about 5 inches from stock. Every road bump, rainwater dip, slight loading while driving is expressed with a quick rebound from the back end of the truck. Horrible ride and I mean noticeable horrible. Granted they will help with a heavy load, but even my wife stated - what is wrong with your truck! Took them off and threw them away. Installed Firestone airbags (professionally done) ... only when loaded do you notice a ride difference. That was my experience.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
^^^ Some darn good points.
Personally, I have SumoSprings. I can swap them out with the factory bump-stops in about 15 minutes. Sumo is much more progressive than Timbren.
I don’t tow a trailer often enough to use air bags or any other devices
MJG44
MJG44
Toronto
Hmm, yea I have a ~5" flip and looking for something to help when I occasionally have the rear loaded. Hoping to steer clear of air bags.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
You might try calling them and speaking with them directly and see if they have something. The kit they have listed for a 2024 Powerboost only has 1.5” before the rubber spring contacts the pad. I don’t see how that could possibly work at all.
How much clearance do you have between your axle housing tube and your bump stop currently?
The_Auto_Tech
Cody
Des Moines, IA
2022 XL 4x2 3.3
You'd need low profile Timbrens, otherwise you'll just be sitting on top of them the entire drive.
