waterwoodf150
- Thread starter
- #1
2021 F150 Powerboost with 39k miles.
Noticed about 5k miles ago that at around 60-70mph there is a light grinding/vibration that I can feel in the gas pedal and steering wheel. You can also hear it even though it’s a bit quiet. You almost feel it more than you can hear it. It sounds/feels repetitive almost like the sound of a bad wheel bearing. But I’ve had bad wheel bearings before and this is only at high speeds between 60-70mph. I also did the swerve test to see if the noise got louder or quieter and it stays constant either direction I swerve. Sometimes the speed of the sound may vary about 1-3 cycles per second. Brand new tires this past weekend so I can rule that out. Could this be the rearend? Driveshaft? Something vibrating under the truck due to the wind speed?
