West Virginia LED Third Brake Light /w Bed Camera
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
I retrofitted this on my 2024 King Ranch and removed it when Ford bought the truck back. The truck was pre-wired for the camera and only required ForScan programming.
$280 shipped from Charleston, WV
Ford F-150 LED Third Brake Light /w Bed Camera IMG_4175
Ford F-150 LED Third Brake Light /w Bed Camera IMG_4174
Garrett
HTX
2024 F150 CCSB XLT 4WD 303A High
Pool Service Company Owner
How would I know whether or not this will fit my truck? I have a 2024 with I believe the 360 camera package. There’s an extra one on my display menu I think it’s trailer. I can check in the morning. I’d consider buying it. I have a rear mounted pool vacuum that would be nice to see from higher up. On my 2010 Lariat I used to have one of those RV wireless cams magnet mount to the roof.
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
If you remove the screws holding in the third brake light and look at the harness connected above the headliner you’ll see the wiring. If the connector has the wiring that looks like this photo, then it’s prewired. If it only has a couple of wires, then it’s not pre-wired.
Ford F-150 LED Third Brake Light /w Bed Camera IMG_4363
Garrett
HTX
Okay. I will take a look this week
Haven’t had a chance to pull the light off yet. Is there any tricks I need to be aware of, and are these as finicky in terms of sealing to the cab as the 12th gen was? About high tight do you do the screws? Any issues with leaks? Considering checking them with a torque driver before unscrewing.
I did the Forscan change to get the banner off of rear view camera at speed last night. I noticed that 360 camera is already enabled on my truck so I do have that, which I assumed because I can use it when parked. Also noticed a setting for:
Center High-Mounted Stop Lamp (CHMSL) Camera
Likely is compatible but I’ll make sure. Have a pool filter in the bed on a pallet today and man I’d like to watch it while driving.
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
No. The screws aren’t very tight. Once you remove the screws you’ll need to pull on the light in a few different spots to break it loose. It has guides to line it up when reinstalling. It’s a simple swap to change it.
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
It’s still available.
