Lariat grill paint match needed.
mrblonde
AZ
2023 Lariat 502 PB
I have a blem on my 2023 plastic grill. Does anyone know a good color match?
mrblonde
mrblonde
AZ
2023 Lariat 502 PB
This dark grey
Ford F-150 Lariat grill paint match needed. IMG_20250709_162708857_HDR
Davidwnuc
Mississippi
On order ‘22 RCSB.
Best bet is to see if a paint shop would sell you something or give you a “close enough” mix code.
i have used these guys before with good results. https://www.automotivetouchup.com/
i just doubt you will find something online designed to match that part of the truck. I could be wrong.
Porpoise Hork
Bret
IT Sys Admin
It's not a painted part so you're going to have a hard time matching it with off the shelf paint. Depending on the severity of the damage it might be easier to buy a replacement grill off Ebay. The price ranges from $100 to $200 +/- for an OEM pull like this one. I hated the chrome XLT grill on mine and got the grey Lariat grill for it instead. Took about 45 minutes to swap them out and was a perfect fit. Hardest part was disconnecting/transferring the front camera washer and radiator louvers to it. Just make sure to not power the truck on or anything with the front camera disconnected. Otherwise you'll need to recalibrate the front camera. Well if you have 360 cams that is.
Another option or see if one of those mobile paint guys can match the color however no idea how permanent this will be since the OEM part isn't painted.
mrblonde
mrblonde
AZ
2023 Lariat 502 PB
Thanks for the replies.
