ISSUE: No Crank / No-Power Up (Unresolved)
suprasteve
Ontario, Canada
2021 F-150 XLT
2021 F-150 2.7L 302A - Aug 6 2021 Built KC blend date
13,180km (8,189 miles)
I had a no-start/crank/power-on in February. After closing the door, dash and infotainment splash screens came up then went black. Odometer did read but distance to empty showed dashes. Depressing the brake pedal caused the green light on the start button to flash rapidly, with a relay clicking heard at the same frequency. A short press or holding of the start button did nothing, whether my foot was on the brake or not.
I called roadside assistance. When they arrived 2 hours later, the truck turned on like normal and restarted fine, cranking quickly without boosting. The tow truck driver pressed the start button using the keyfob itself; but I have no idea where the receiver actually is. It has been fine since, and I have put on another 4,000km. Battery terminals are tight. No CEL.
Dealer has not helped much; "no fault found, maybe TSB 22-2109" this TSB doesn't seem applicable at all...
Anybody else experience this? Potential key communication/interference issue? Software bug?
Kanuck
Winnipeg, Manitoba
Retired Electrician
If the truck can't read thee flob, then you should get a error message on the screen. See page 75 in the manual, top right hand corner.
suprasteve
Ontario, Canada
2021 F-150 XLT
got ya, I did test that as well and it did not behave that way when the fault happened. just a black screen.
PnchDrnk
2023 F150 Lariat Powerboost 6.5
Hey Suprasteve I know this is an incredibly old thread but I was wondering if you ever found a reason and solution to your problem?
Kanuck
Winnipeg, Manitoba
Retired Electrician
I discovered that when I am at a local drive up instant teller, sometimes my truck can't see the fob. I found out, that I was not the only one. Some kind of electrical interference around the instance teller. Told my salesman about it. He had to go there, put the customer's fob in the slot, to get her truck started. Then, he had to do the same to his truck to be able to leave. All at the instant teller.
Edit should add, this was just after I got my truck...summer of 21. I know what to do now if it happens. Put the fob into the programing slot under the cup holder.
2nd Edit.. sorry, I forgot it is a secret place that nobody knows. :teehee:
