Intermittent hum or howl from front end
Beef_Stew
Aaron
2022 F150 XLT sport CCSB 5.0
Auto Body Tech
Been experiencing a hum/howl from the front left of my 2022 F150. It’s happened 4 times now over the 5 months I’ve owned it. 3 times at the exact same spot, going 45mph and slightly turning right. It sounds like a wheel bearing hum or howl that lasts for 15-20 seconds then goes away. Almost sounds like going over a rumble strip on one side. The last time it happened I put it in 4wd and it immediately went away. Anyone else experience this before? 3800 miles
tony72cutlass's'
Tony
Halifax
Wheel bearings normally have a high pitched squeal when they blow. Other than the vibration did you hear any noises?
My first gut instinct would be to check your lug nuts for looseness / proper torque
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
Checked lugs, those are good. It was like a low pitch humming/vibration noise
tony72cutlass's'
Tony
Halifax
Hmmm, odd that it went away when you put it in 4WD.
I’d probably take a tech for a ride along and show them exactly what it is in case there’s a recall on something. Most of the time if I hand them the keys they’ll just say they can’t hear/feel it.
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
That’s what I’m thinking. I’ll see if it happens again, and I’ll take it in
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi Aaron. Can you send us a DM with your VIN and dealership info? I can look into this for you.
What you describe is the exact symptom of an IWE that is partially engaged when it shouldn't be. (in 2WD, the IWE should not be engaged. In 4WD it is, thus the grinding of a partial engagement ceases)
This should be rare on a Gen14 truck because Ford finally replaced the vacuum operated IWE with an electric IWE. Or in my 2022 Powerboost, eliminated the IWE altogether.
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
Very interesting. I’ll have to do some research and see if anyone else has had any IWE issues. Seems like the issue only appears when traveling 45 and slightly turning right (making noise on front left)
Honestly, yours is the first post for a Gen14 truck that sounded like a very common post for the previous 20 years worth of 4WD F150's.
Of course it's entirely possible that you are not experiencing a momentarily partially engaged IWE, but your description is very similar. Especially when you state that it doesn't do it in 4WD. (since 4wd fully engages the IWE/hub and the noise/vibration immediately ceases)
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
Exactly right, once I hit 4x4 it disappears. With all the symptoms and where the sound appears to be coming from, it seems like a sure thing. But strange nobody else has had an issue, maybe I’m just the lucky one. We will see how it acts the next few weeks.
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
I have the same issue with my 2022 XLT with 300 miles on it, same speed (around 45). Mine sounds almost like when a fender liner is stuck on the tire.
Yes exactly the same as what I’m hearing!
lb7mike
2022 F-150 XLT 3.5EB
Unfortunately I had to push my appointment back to next week due to the holidays. However, it has given me some time to note a few things about this noise:
1. It always occurs during my morning commute, and within the first 1.5-2 miles of my drive. I have never had it happen twice in the same day.
2. It always occurs between 45-50ish mph
3. Mine seems to be coming from the driver front more so than the passenger.
4. It seems to be an actuated (for lack of a better term) noise. I say this because it always lasts the same amount of time (roughly 10 seconds). Slowing down, speeding up, or switching to 4wd seems to give the illusion of stopping the noise, but I a almost 100% convinced it has now impact on how long it lasts.
5.The more I listen to it, the more it sounds like a mixture of an ABS activation-like noise and that of a fender well rubbing on a tire (just noise similarities, not saying that’s what’s happening).
6. Lastly, I really don’t know much about these trucks as I bought this as an fill-in between selling my 21’ F-250 and waiting for my 23’ 350 that I ordered to come in. But, my theory lies with either the front air dam actuator, abs actuator, or the 4wd Hub actuator. Again, I know next to nothing about F-150s and how the systems that I listed operate, but it for sure doesn’t seem like a hub bearing, transmission, or transfer case issue. I am trying to gather as much information as I can before the truck goes in for service as my dealer is pretty receptive to input.
Beef_Stew
Beef_Stew
Aaron
Auto Body Tech
Thanks for the update be sure to keep us posted. What you’ve described is exactly what I’ve been hearing. My first thought was something sounding ABS related also. I’ve only heard it 4 times 45-50 and within the first 1-2 miles of my commute is accurate also.
