help with stereo
mikey1988
MIke
norfolk, ontario, canada
'21 Ford F150 XLT fx4 reg cab V8, '79 Ford Granada
steel mill worker
hello everyone, i have a 2021 rcsb xlt 301A F-150 and was a little disappointed to find out that the 8" touch screen radio only has front speaker outputs, does anyone know if the plug on the back has the pins for rear speakers and subwoofer outputs and if so is there a way that i can use forscan to add the rear speakers and subwoofer to my truck so i do not need to cut or splice into any wire harness?
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
So the radio should be the same in your truck as it would be in a ext. cab etc. I would think you could just pin in the rear speakers into the harness. And then use forscan to turn on the fader etc.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
Does yours just have 4 or 5 speakers now? If so, the outputs are already pinned for the rear, just need to run wires from the plug shown C248 prob tied up under the dash under the radio. None of the ACMs have subwoofer outputs, they all use a factory amp; so you’d just have to tap into the door speakers and add an amp (which I think is better anyway than dealing with the factory amp).
Ford F-150 help with stereo 3E3AC7A7-F1C3-42B7-9748-C92B231F1691
mikey1988
mikey1988
MIke
steel mill worker
My truck has a speaker in each door, one in the A pillars and i believe there is one in the top dash pad
Zyvin
SC
Yours is the same as the first picture plus the dash speaker; see below. I also updated my first post with some subwoofer information.
Ford F-150 help with stereo 3B2307D9-D2FD-47C7-8AD9-1CAF8BF8FBCC
mikey1988
mikey1988
MIke
steel mill worker
Cool thqts good to know, but is there a code for forscan to activate the rear speaker outputs because i am guessing of i wired up some 6x9s to those wires they still wouldnt play
Zyvin
SC
Yes, I believe you would. Don’t take this as fact, but I’m guessing 727-01-01 xxxx-??xx-xxxx would need to be changed for speaker #3 and #4 output.
mikey1988
mikey1988
MIke
steel mill worker
looking at Livnitup's forscan sheet i think you are correct ACM 727-01-01 looks like it is the radio if you or anyone else has a ext cab or quad cab with the basic stereo would you be able to check and tell me what the code is? the spread sheet has a bunch of different codes for the rear satellite speakers
i cant be the first person to have a reg cab truck and want the fader function... yet all the forums i have checked i have come up with no info
Zyvin
SC
I have the 18 speaker system, but my rear doors are still run off of the ACM like you want yours to be. So, maybe my settings will work. Look specifically at the asterisked items in 727-01-01 xxxx-**xxx-xxx, and 727-01-03 XXXX-XXX*-xx--. That should be the settings for speakers 3 and 4.
The fader menu will have to be added in the APIM, I believe. Look at 7D0-01-01 X*xx-xxxx-xx--.
Here are my settings for the ACM:
727-01-01302B14FD10AC
727-01-028900000900C3
727-01-03000000000032
Davidwnuc
Mississippi
On order ‘22 RCSB.
following
you guys are awesome. I have plans to add a subwoofer in the future and this info is perfect
