Help with o2 sensor reading
rcan6
South Carolina
2021 F-150 5.0
These are my two downstream O2 sensor readings at idle. I know the graphing is probably supposed to match. I don’t have enough mechanical understanding to know if the strait line graph or the fluctuating graph is the sensor with a problem. Thanks
Ford F-150 Help with o2 sensor reading IMG_2886
Ford F-150 Help with o2 sensor reading IMG_2884
ttnuagmada
Adam
Tyler TX
2021 F150 XLT Sport FX4 5.0
Mine both sit at a steady .74-.78ish at idle. The fluctuating doesn't look normal. Disclaimer: I'm not super experienced with this stuff either.
ttnuagmada
Adam
Tyler TX
If you were curious, here's me sitting at idle after driving for about 30 minutes.
Ford F-150 Help with o2 sensor reading 1000001889
Darrell78
Ontario Canada
2022 f150 limited PB
Tech
What are you trying to figure out? Those both seem ok to me. Small fluctuations is normal especially if it's idling. Bring the rpm up for 20 seconds and it should smooth out. If it were a bad cat it would swing alot more then that. But like I said what problem are you looking for?
