Huttar13
- #16
I wasn't able to get much slack out of the harness but what I did was pull the rubber boot back and cut away the harness tape to give me better access. Good luck. ASadly I did not see this post and am dealing with this too, except it was a cruise control wire. How'd you get so much slack to pull out? I unhooked the connector all the way up there and it doesn't want to pull out that far. It was also easier for me to go through the wheel well rather than remove the fuse box. If I can get enough wire to show, I could get right to it.
