Heat exchanger - I thought I was over this crap
Mosey
2021 F-150 Powerboost
Ugh, my 2021 PB just threw codes P2C22 and P237C, both heat exchanger related. I had the bloody thing replaced this past summer. It is not leaking - no coolant level decline. I cleared the codes but one of them is permanent.
I thought I was over this crap.
Nasto
Neil
Eagle, Idaho
2022 F-150 Lariat SuperCrew
iceman77
Pete
2022 Ford F-150 Platinum
Yup, same thing happened to me! Muffler inlet pipe (with heat exchanger) replaced last April, after 24k miles started throwing P2C22 and P237C codes at PCM with CEL illuminated on dash. No leak from heatexchanger though. I got extremely lucky this time, as the dealer had the part available at their shop and I had my truck in and out in one day, with heat exchanger replaced (again!)
It seems to me, that the heat exchanger valve actuator fails over time. This is however not a Ford product, the actuator itself comes from the SBS-Feintechnik, a german company that supplies such products to other big brands such as BMW and Audi.
Ford F-150 Heat exchanger - I thought I was over this crap 1677797615670
I am not sure why is Ford not replacing the actuator itself (it can be removed from the heat exchanger assembly failry easily) but they are replacing the entire heat exchanger assembly. I am sure the actuator replacament itself would move things faster, assuming there is enough supply of that specific part
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
Did the truck go into limp mode with the P2C23 DTC?
amschind
Adam
Physician
Also, I am in the market for a dead heat exchanger assembly, so let me know if you want to sell yours.
