- First Name
- Bruce
- Joined
- Jun 19, 2021
- Threads
- 5
- Messages
- 11,560
- Reaction score
- 22,964
- Location
- Coastal Texas
- Vehicles
- 2022 F150 KingRanch Powerboost
Here is the code information
In my opinion, they are following the procedure in the factory service manual that was written PREVIOUS to the CSP.
Or put another way, early on with the exhaust heat exchanger related issues, Ford would replace the "intermediate" exhaust pipe if ANYTHING was not performing perfectly. If the $5 coolant tube was leaking, Ford replaced the whole intermediate exhaust pipe. If the exhaust valve solenoid threw a DTC, Ford would replace the intermediate exhaust pipe.
It was a shameful wasted of time and resources, but typical of a huge corporate bureaucracy.
Here is the instructions that I believe your dealership is BLINDLY following.
This is the pipe:
(Note: Ford has since made the tubes (red circle) and the solenoid (blue circle) available separately, thus no longer needing to replace the whole exhaust pipe assembly
I personally believe that the CSP is intended to override the pinpoint test procedure conclusion in the service manual. Certainly if the real issue (DTC) is solved by replacing either the coolant tubes (leaking coolant) or the exhaust valve solenoid.
I'm sure that it is possible to have an issue with the exhaust heat exchanger assembly that is NOT either a leaking coolant tube and/or the exhaust valve actuator-solenoid. But I can't give the technician the benefit of the doubt that they would KNOW the DTC P2C22 isn't a malfunctioning solenoid.
By the way, if condensation in the exhaust valve freezes during cold temps, the DTC can be triggered because the valve is frozen. In just a few minutes, the exhaust melts the frozen condensation and the valve becomes functional again. So you'd have to clear the DTC and then verify whether it returns or not.
Only applies to you Northern Powerboost folks, of course.
This is the pipe:
