Headlight lens replacement a DIY?
NY Cowboy
Miami, FL
2021 F-150 Lariat & 2015 Transit T-250
Contractor
I have a 2021 Lariat PowerBoost and a rock hit the passenger side front headlight and busted the clear lens. Is this a job I can do on my driveway? Any thoughts?
Ajzride
Automation
I just went through this. I was never able to get the lens off the housing. I tried a heat gun and never could get the adhesive to soften. I then started with the oven (the light is massive, it barely fits in a house hold oven) and I started at 200F and worked my way up to 275F. I couldn't get it soft at 200, 225, or 250, and at 275 the entire thing melted spectacularly. I suspect the issue is how close it was to the heating element since the light is so big. if you decide to try it yourself, be sure to take the light out of the oven every time you change the temperature set point and then put it back in once it reaches the new temperature.
Do you have LED projectors or LED reflectors? My driver's light was busted so I have a spare passenger, it is the LED projector style.
Jmet8
South
Bronco
Check eBay or car-part.com for that one. a swap not so bad. Trying to get these apart is hours of work and need to go in the oven mutple time to heat up the the black stuff holding to the housing . I watched some videos on these 21 and up was like well I’ll be just doing a swap. Good luck.
NY Cowboy
NY Cowboy
Miami, FL
Contractor
I think it is the projector LED as the truck was outfitted with just about every bell and whistle.
NY Cowboy
NY Cowboy
Miami, FL
Contractor
LED protjector type as I ordered most all upgrades to the truck when ordered.
Ajzride
Automation
Let me know if you are interested in mine. It's sitting in a box waiting for someone to buy it.
NY Cowboy
NY Cowboy
Miami, FL
Contractor
What is my cost?
NY Cowboy
NY Cowboy
Miami, FL
Contractor
"We spent about 5 hours in the oven with these as they're sealed inside and outside"
Ajzride
Automation
I guess I was just too impatient. I've never had to leave a headlight in for more than 30 minutes before. I was really worried about leaving all of the electronic components inside the light in the oven that long. I was worried about solder reflow.
