Got my TPMS and Trailer camera in the mail today...Trying to figure if I need a Trailer Yaw Rate Sensor Kit
Bobcatou
Bryan
Port Townsend, WA
Website
listentothewindmedia.com
'24 Lariat, (Carbonized Gray Metallic)
I found instructions on how to install my TPMS and Trailer camera though the link Ford gives you get with the system doesn't have them on the website. :rolleyes:
Anyway I am trying to sort out whether I need a Trailer Yaw Rate Sensor Kit that is talked about in the instructions. (attached quote)
I'm thinking I don't need this because I already have the stickers. From looking around this board, it appears this was used for the Sync 3 system. Can someone confirm that?
I attached the instructions to the TPMS and Trailer camera system I found (For 2022+) below too. If it turns out to be wrong for my 2024 Lariat, I will let you know.
Ford F-150 Got my TPMS and Trailer camera in the mail today...Trying to figure if I need a Trailer Yaw Rate Sensor Kit CleanShot 2025-04-02 at 20.48.46@2x
Buyer2021
central TX
retired!
You don't need the yaw sensor unless you're not happy with the stickers and want backup assist. If you want to add the sensor and remove or cover the stickers it should (no guarantee on a 2024, but it works on a 2022 :wink: ) function with your truck (I wouldn't try running both at the same time, that might confuse something!).
It's not required for the cam / TPMS to function, if your kit has the harness branch for the yaw sensor it can just be tucked-away somewhere.
Bobcatou
Bobcatou
Bryan
Port Townsend, WA
Website
You don't need the yaw sensor unless you're not happy with the stickers and want backup assist. If you want to add the sensor and remove or cover the stickers it should function with your truck (I wouldn't try running both at the same time, that might confuse something!).
Thanks...Good to confirm.
I saw they Yaw setup sells for about $130 online and $100 on Ebay.
The stickers aren't perfect, but I am happy with them for now. Might be an idea for a project later on, but there are more important things before that.
Buyer2021
central TX
retired!
Please note my '2024 caveat' added after you quoted me - with Ford these days there's just never any telling what they might have changed, lol.
Bobcatou
Bobcatou
Bryan
Port Townsend, WA
Website
I see. I would definitely triple-check.
Gary
Gary
Does your new kit wiring harness have the plug for the YAW sensor ? It is referred to as “D1” in the instructions.
Gary
Gary
Bobcatou
Bobcatou
Bryan
Port Townsend, WA
Website
No I don'w have the plug for the Yaw sensor. I figured out my truck didn't need it
