I should have cleaned the dirt off before I took the pictures.I know you took those pics for another member, but they're helpful. Thanks. They seem to fit really well.
I have the TripleA full width mat on my regular cab and like it... the fit is tight. My truck has the factory carpeting and has the floor clips. I'm actually considering strategically cutting the center hump out and making it into two side mats. No slush or mud will ever get up on the hump, and it will make it easier to remove/install.
Just need to carefully mark the cut line with tape while installed to ensure the cut is clean and in the best spot. Like I said, the fit is tight so I believe it will not sag or leave a gap at the floor. Especially with carpeting I think it will look better leaving the hump uncovered. I'll post photos if I do it.That's actually not a bad idea.![]()
Thanks for the photos. Those are the ones I’ll be getting.I should have cleaned the dirt off before I took the pictures.
