Front Parking Sensors adding to new truck
TrueBlue
Dan
2023 F150
Hello new member here from Canada!
Picked up my new 2023 PB XLT High package after waiting to see what spec a 2024 can be with Bench from seat ! (turns out not much) so jumped on one of the last 2023.
I have the chrome package which I need to remove as not a fan myself, I do not have 360 camera or front parking sensors, Can I add front parking sensors ? I am just about to order new front and rear bumpers so I could order with holes and grab the sensors too?
I have searched the forum but not seeing if it can be done OEM?
Thanks in advance !
thunderf150
Max
Ontario, Canada
2023 F150 Lariat 501a
HR
Congratulations on your new truck.
You can for sure add the sensors but it will require more than just the sensors. New wiring and checking if you have the right modules already installed.
I guess that you might already knew but as far as adding sensors is considered there are number of thread which talks about installing these sensors.
Example:
https://www.f150gen14.com/forum/thr...sor-installation-guide-for-gen-14-f150.20662/
And
https://www.f150gen14.com/forum/threads/adding-forward-sensing-system-2021-king-ranch-w-601a.9039/
TrueBlue
Dan
2023 F150
Thank you for the reply’s and information really appreciated.
I have read through these and also touched base with my ford dealership, they mentioned it can be done but I would have to add additional safety features to make it the same as a lariat, then they can update the software the same……..
Wow 300$ Cad per sensor!
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
How much will new bumpers cost? Your going to have to get them painted as well?
Jesse-Infotainment
Jesse
2024 F150 Lightning
Youll need a nEw IPMA also.
TrueBlue
Dan
2023 F150
Which IPMA ?
Should I add anything else if I am already investing in the sensors and new bumpers etc
TrueBlue
Dan
2023 F150
Can you tell from VIN which IPMA the truck has ?
TrueBlue
Dan
2023 F150
Probably easier to retro fit a bench seat in a loaded lariat at this rate !
