I will try this and I have forscan as well@Harveen Harpreet, it could be the IPMA module which looks after cameras, BLIS, radar and park sensors. It may not have reset properly after the update. If you have FORScan, I would reboot the IPMA. If you don't have it, disconnect the positive battery terminal for 30 minutes, reconnect and test.
I will try this as well todayTurning this on for my '22 Platinum was the first Forscan update I did. Not sure if this is the problem, but you might take a look at this value in Forscan.
https://www.f150gen14.com/forum/threads/22-f150-plat-change-front-cam-activation.14621/post-299428
I will try this today thanks dearTurning this on for my '22 Platinum was the first Forscan update I did. Not sure if this is the problem, but you might take a look at this value in Forscan.
