BeauFlexFP700
Noticed an odd sound on a cold start one day. Only lasted a few seconds and was unable to reproduce it at first. It would only happen sporadically on cold starts, usually on the first start after not being driven for a day or 2. The best way to describe it is like when you blow up a balloon and then pinch & stretch the neck and it makes that squealing sound as the air escapes. It recently started doing it consistently on startup, cold or warm, and will actually do it during driving. It happens when the throttle is first engaged from a stop or when accelerating while driving and only during the the initial press of the pedal. It will go away once you've gone past half throttle. It will linger under light throttle but not consistently. Since it became more prevalent I tried to determine where the sound is coming from and as far as I can tell it seems like the bypass valve is the culprit. I will post a video if I can where I pointed the camera at the bypass valve and started the truck and gave it some throttle.
sounding great. I am thinking the air leaking in at that adapter plate was causing a lean condition maybe? At any rate it was doing something that was causing problems and was probably slowly getting worse until it finally started making the squealing noise and making an already precarious situation with the factory cats even worse. Ive heard other people complain of a mystery "whistle" or "whine" on partial acceleration/throttle. Maybe check the bolts on that adapter plate if you have the stage 1.
