Forscan Questions
Pennsylvania
22 F150 5.0
I have a 22 f150 5.0. I made a couple of changes with forscan, including Bambi mode, removed the “full screen not available”, and removed the double horn honk. I followed livenitup’s forscan spread sheet and tried to enable cameras at speed, it didn’t work. Not sure what I missed. Anyone else run into this? Also has anyone figured out how to keep the mirror spot lights on at any speed.
thanks
KTM753
I ran into the same issue with cameras at speed changes listed on the first page of the spreadsheet not working for my 2021 XL. Now the button doesn't work in Drive anymore and when at speed the button does work to show zoomed in on the hitch. Not sure what my issue is. Have you tried to use the button at speed?
I need to buy another 1 year Forscan license and try working on this again. Maybe we can help each other.
Silverbullet5.0
Pennsylvania
22 F150 5.0
I would go back and put it back to as built, make sure everything works and try it again
My button on the dash works as it should. If I’m stopped and press the camera button, the front/360 view shows up but at about 8 mph it shuts off. My bed/rear/hitch can work in motion. Just not the front camera.
KTM753
The first line of the spreadsheet for cameras at speed says to change the values in the IPMA. When looking at my saved as built data I don't have a file for IPMA...
Looking deeper in the spreadsheet at 706-02-02, I see the following heading:
FeatureCfg_DPAC_ViewCtlAtSpeed_Hitch (FCDPACVCASH) • FeatureCfg_DPAC_ViewCtlAtSpeed_Aux (FCDPACVCASA) • FeatureCfg_DPAC_ViewCtlAtSpeed_CHMSL (FCDPACVCASCHMSL) • FeatureCfg_DPAC_ViewCtlAtSpeed_RCOD (FCDPACVCASRCOD)
What does each of those do?
First line is enabling hitch view?
Second line is Aux view if you have one?
What does CHMSL mean?
What does RCOD mean?
Silverbullet5.0
Pennsylvania
22 F150 5.0
i am honestly new to this whole forscan thing, so im not sure. Hopefully someone else will see this and be more help than me. @Livnitup made the spreadsheet, maybe he can help us.
RickBullotta
Rick
Pennsylvania
2021 F-150 Lariat Powerboost
If I recall correctly, the settings for cameras in motion varied based on the year and other factors - @Jesse-Infotainment helped me get mine working again after a software update a few months ago.
JRonchetto
Jim
Missouri
2021 F-150 XLT 302A
CHMSL is an acronym for Center High-Mounted Stop Lamp. I'm not sure what RCOD is.
antho
Anthony
Houston, Texas
2024 Raptor 37
@Silver Bullet did you make any changes in IPMA? It’s hard for any one to help without knowing exactly what you changed.
RociPB
21-F150-XLT-PowerBoost
thanks
Which item on livinitup’s spreadsheet did you do for removing the full view not available? That is the black rectangle on the back facing camera right? It is actually one of the dumbest programming/UI decisions I’ve seen in a while, it isn’t even critical info for the driver yet it takes up 30% of the center of the camera FOV ?
Silverbullet5.0
Pennsylvania
22 F150 5.0
On the spread sheet, under common, I did cameras at speed. It’s the first one there. Last night I realized that the one underneath it that says “enable off-road” says front cam at speed at the end of it and I didn’t see it. I have been busy with work and haven’t had time to enable it and see if that’s what I missed. But I’m pretty sure that’s it and it was my own mistake.
