AJ⚡️
I recently acquired the truck I have now 2021 F150 Lariat it’s got most, if not all, the bells and whistles. It also appears to have had a small lift in the front (not quite leveled). I’ve noticed that my auto level headlights shine just a little low, so I did (or tried to do ) a headlight calibration through forscan, however just about as soon as it started it said the procedure was interrupted, and the truck threw a message that said, check headlamp system see manual. I can see through forscan on the headlamp module it has some code’s related to the front sensor, one something about voltage low and one about needing calibrated (which I was trying to do but it won’t let me ) any ideas what happened or what the solution might be ….
