V5 = severe downgrade…. See previous 10,000 posts.I noticed since FordPass got updated to 5.0, I can no longer refresh the vehicle status and location via swipe down on my iPhone screen. When i did the swipe down, nothing happens. Anyone else have this issue?
Not being able to manually update had me hoping it meant the status was updated more frequently. Guess notLol, my truck says it's running 18+ hours after I parked it! ? ?
You could try clearing the cache and data in Fordpass, you'll have to login to Fordpass again after doing this. But it will automatically reconnect to the truck.I having this exact problem now. Locking in the app will make it update the status of my truck but I didn’t have to do that before.
This happened after my battery got changed and APIM got master reset. I had to activate my truck with Fordpass again and it hasn’t been the same since.
I actually deleted FordPass, re-installed, and logged in again. It still has the same problem.You could try clearing the cache and data in Fordpass, you'll have to login to Fordpass again after doing this. But it will automatically reconnect to the truck.
Gotcha, ya it was just a thought, I saw the problem you're having with the update. There's got to be more to it then. Definitely post your resolve when you figure it out. Good luck. ?I actually deleted FordPass, re-installed, and logged in again. It still has the same problem.
I saw that you had the same issue in May. Did it eventually fix itself?Gotcha, ya it was just a thought, I saw the problem you're having with the update. There's got to be more to it then. Definitely post your resolve when you figure it out. Good luck. ?
