Flexin_Chunsik
I'm considering 2023 F150 XL 5.0 V8 regular cab, long bed with HDPP and offroad option for purchase. Not sure if custom build for 2023 model is still available though. I'm planning to build a lightweight custom camper directly on the frame after removing the bed. 6x8x5 box for the camper shell made of aluminum tubing to achieve lightweight. Considering the payload gain from removing the bed, I'm trying to limit the net weight added to the truck including camper and gears, etc to 1,000 lbs without passengers (me and my wife). 2024 model still offers 2000+ lbs payload capacity so I don't think the weight is going to be an issue.
I might've got a bit sidetracked but my main question is related to fitting 37s. I'm not into rock crawling but my offroad trips with the rig will involve moderate trails requiring some ground clearance and wheel articulation. I have a Jeep Gladiator (which will be replaced when I get an F150) and 37s on the Gladiator is a bit of overkill for my use but have provided me comfort and confidence on technical trails and I'd like to a similar level of assurance when tackling trails with the F150. And not to mention that truck looks so much cool with 37s! I plan to add rock sliders and skid plates for the engine, tranny and fuel tank for offroad use. If needed, I'll replace the fenders with wider one like Raptor's. I found knock-off Raptor fenders online and they claim the wider fenders provide additional clearance. Not overly concerned about power loss or bad fuel mileage with 37s and added weights as I'm used to the 3.6 minivan motor in the Gladiator lol. I know V8 5.0 will have a lot more HP and torque so I will be happy with that.
I've done some research and found a setup in the search that XL V8 5.0 regular cab with 6.5 bed with 3" spacer and some minor trimming clears 37s. The owner's profile says he's a welder so I'm not sure what his definition of "minor" trimming is lol but at least he confirms 37s are doable with 3" lift. Most of information I found online was recommending 6" lift but I want to stay away from a tall lift to minimize raising the CG. Adding a camper feels like it's already pushing the offroad limits...
So I just wanted to get some additional inputs on fitting 37s with minimal lift since I don't feel comfortable moving forward with the plan based on one post suggesting 37s are doable with 3" lift. I'd love to hear successful stories of fitting 37s with less than 6" lift. Also while I'm posting for this question, what other suspension/drivetrain components need to be replaced/reinforced when you add lift and beef up the tire size? I'm new to Ford world but from my Jeep experience, anything more than 3" lift requires new driveshaft, arms and trackbars to adjust the geometry as well as re-gearing. I want to lift the truck and fit 37s in the right way without compromising the vehicle balance and offraod-ability.
This post is getting lengthy. I appreciate your time in reading this and look forward to some good discussions!
