Finally got second gear issue fixed
HANCOCK
HANCOCK
Bob
South New Jersey
2022 F150 powerboost
On the Powerboost 10r80 MHT, the service manual states:
So I think you are good.
Looks normal color to me, but I'm no expert. As long as it doesn't smell burnt and lost its clarity, I would think it's fine?
thank you
Having never seen that trans dipstick before, I find the numbering very counter intuitive that a lower number represents a higher fluid level. Isn't that kind of ass backwards? ?
And on some of the dipsticks you will find abcdef instead of numbers
Who knows why they think these things up?
Why not etch into the plastic stick a range of "good" for that 10r80?
Takes the guess work out.
Gros Ventre
Western Wyoming
Note: When that manual says don't overfill, it means it. I had my dealer change transmission oil & filter. They had a procedure that wasn't clear on how much to refill with and ended up overfilling it. The engine would start but the transmission wouldn't budge the truck. Trouble shot it for some 10 or 11 hours, including disconnecting the main battery to "reset things." It wasn't until I spoke with them and said "You know, that little battery in the backseat area is surely a keep alive memory battery" and you need to disconnect it too in order to clear out all memory, that they could get the truck to operate. Somehow it knew that it was overfilled and that that is a bad thing... :)
Gros Ventre
Western Wyoming
So what happened to the days when people were expected to know something about their cars? You know, use the dipstick every so often, change the plugs & points, knowing that there are two sets of marks on the transmission dipstick (one for cold and one for hot level checks), check the air in your tires... well you get it... Daggone things are smarter than I am these days... My biggest fear is the stop safely now warning in the middle of nowhere with no idea of what's wrong... In those bygone days cars would let you know by vibrations, noises etc that something was coming. Now that computer compensates until everything just dumps...
HANCOCK
HANCOCK
Bob
South New Jersey
that is too much common sense to put (good) on a dipstick !! These are engineers that we are talking about . They are very smart but no common sense
Knight’s Garage
Randy
Birmingham, AL
Website
www.youtube.com
2023 F-150 Platinum
I have searched for this information here several different ways and this is the closest ive gotten so ill ask you to see if you can help.
I have a 2023 with the 5.0 engine. What level should my trans be at, at operating temperatures? My dipstick has the numbers like you show here. Thank you!
I'm sorry, but my copy of the service manual is VIN specific, so the transmission pages are all specific to the 10r80 MHT that the Powerboost is equipped with.
The Coyote does have basically the same transmission, but it is possible that the proper fluid level is 1 or 2 segments different on the dipstick. I honestly don't know.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just saw a post saying for the 5.0 it is between 5 & 6 on the dipstick.
Big Dog Daddy
New Jersey
Here you go, good luck
Gotcha on the 5.0 @Snakebitten @Kanuck
Ford F-150 Finally got second gear issue fixed Screenshot_20240129_230307_OneDriv
Ford F-150 Finally got second gear issue fixed Screenshot_20240129_230252_OneDriv
1newdave
Northern California
2019 F150,
Supervisor
My truck was having issues with shifting into gears (Shifting Rough Felt like it was slipping) .Which I was asking how to clear my transmission tables . On a different thread anyway ford Motor company on this forum He said to send him the Vin number and he would check it on his end. So He signed me a case number. Went to the dealer .. I had no problems whatsoever with the dealer they had a loaner car to !
the outcome was Main control valve body . Just got it back today Can't believe it but the truck is shifting Like a Cadillac Very smooth. I'll see how it goes in a couple days if it stays like this Hopefully. They did it OTA Software update 4.2.4 also . Update all the modules also they said .. have to check that . Thumbs up Ford motor company!!!
Question Since Ford fix the main control body you think the transmission it's going to last as long ?
Having same problem with my 2019 F150 rough shifting but pretty sure it is slipping , taking offramp yesterday gave it gas and it just slapped the tach to 4000 rpm scared the hell out of me. so I eased back into it and limped it home, guess I will call my dealer tomorrow and hope it limps the 20 miles ,problem is they are always backed up 2-3 weeks.
