Which ones? I got mine from BK as well.Just ordered some custom badges from Badge King, so we'll see how they turn out. 4 week turn around though. ?
This is the mock up he did for me. Super excited for them.Which ones? I got mine from BK as well.
4 weeks was the estimate i got.
I have been strongly considering a roque squadron red leader theme on mine (rapid red with flat black accents)This is the mock up he did for me. Super excited for them.
That would be pretty sick. He was great to work with getting the mock ups done. We'll just see how they turn out.I have been strongly considering a roque squadron red leader theme on mine (rapid red with flat black accents)
LOL...exact ones I ordered!! LOLMy truck, well when its built, will have the flat black fender badges. I just ordered these to replace the stock badge portion.
I mean no one cares about the trim level, right?
Mine will not have the coyote head.LOL...exact ones I ordered!! LOL
I wonder if you could order the badge seperate from the whole vent / badge combo. Since I have a sport and the vent is already black, it's not really required. Just want to black out the 'F-150 XLT' portion that is chrome.You can get the BAP XLT ones that Ford sells with the BAP packages but it'll definitely be a long wait.
I doubt that you can since the rectangular badge is sort of riveted to the vent piece. The badge has plastic pins that are inserted into holes in the vent piece and then the ends of the pins are melted and flattened to fasten the badge to the vent. To remove the badge you can drill out the melted part of the pins sort of like you do when you want to remove a rivet.I wonder if you could order the badge seperate from the whole vent / badge combo. Since I have a sport and the vent is already black, it's not really required. Just want to black out the 'F-150 XLT' portion that is chrome.
Yes, i just ordered the badge. The rest will remain stock.I wonder if you could order the badge seperate from the whole vent / badge combo. Since I have a sport and the vent is already black, it's not really required. Just want to black out the 'F-150 XLT' portion that is chrome.
It comes off.I doubt that you can since the rectangular badge is sort of riveted to the vent piece. The badge has plastic pins that are inserted into holes in the vent piece and then the ends of the pins are melted and flattened to fasten the badge to the vent. To remove the badge you can drill out the melted part of the pins sort of like you do when you want to remove a rivet.
Negative, you have to order the entire vent, as it’s plastic riveted to it, same as the front/rear emblems. You can take apart your existing, just drill/shave the plastic rivets and remove out the badge part off the vents. Vents are very easy to remove off the truck. Once the chrome letters are separated, just clean it throughly, sand it, hit it with adhesion promoter, primer, paint, then 2K clear coat. Put it back together with plastic epoxy or superglue, you’re done. (Speaking from experience as I’m doing a lot of painting of the rear and front FORD emblems for friends here haha).I wonder if you could order the badge seperate from the whole vent / badge combo. Since I have a sport and the vent is already black, it's not really required. Just want to black out the 'F-150 XLT' portion that is chrome.
Negative. There are many places that sell just the removable rectangle top part of the badge. For much less than the entire piece. 30 secs with dremel seperates the 2 pieces.Negative, you have to order the entire vent, as it’s plastic riveted to it, same as the front/rear emblems. You can take apart your existing, just drill/shave the plastic rivets and remove out the badge part off the vents. Vents are very easy to remove off the truck. Once the chrome letters are separated, just clean it throughly, sand it, hit it with adhesion promoter, primer, paint, then 2K clear coat. Put it back together with plastic epoxy or superglue, you’re done. (Speaking from experience as I’m doing a lot of painting of the rear and front FORD emblems for friends here haha).
