DRL Disable for Canadian Forced DRLs (‘21 F-150)
Nightshade
AJ
Alberta, Canada
Tested the DRL-disable option that can be disabled via FORScan, which is a great feature for us Canadians (not sure if it’s the same for US), I’ve gotten the codes from @Livnitup, huge credits to him! Works great, have zero issues. I tried it on mine and still have it for a few months now. I gave the same codes to my friend as he wants his disabled, works 100% on factory LED headlights! It’s a great option if you need it. The codes to change are below, ignore the “x” and write the number/letter that is in place. This will require the Sync 4 to be rebooted few times (2x for me) before you can see the Daytime Running Lights toggle on Sync 4 screen (Settings, Vehicle, Lighting):
IPC 720-02-01 xxEx xxxx xx--
APIM 7D0-09-01 xxxx x2xx xx--
BCM 726-21-01 0101 0101 01--
BCM 726-27-02 xx01 xxxx xx--
Ford F-150 DRL Disable for Canadian Forced DRLs (‘21 F-150) 3ACA15F9-6213-46F1-8DB2-1A9D71042E08
mxc27
Ontario
2021 F-150
This seems to disable the Canadian-only Glare-Free Headlights. I can check on mine this weekend.
Ryanf150
Ryan
Wv
2021 f150
I tried this and my low beam still stays on in the Auto position. Any ideas?
Nightshade
Nightshade
AJ
Alberta, Canada
DRL led bar gets brighter when you use the light switch in mode 2. You’ll notice it at night or during the day when it’s parked. During the day in mode 3 (auto) it’s already defaulted to being really bright. This mod makes it remain bright in switch mode 2.
