Lippy
Background: I'm aware door alignment has been an issue on F-150s for quite awhile, and the panel stamping of aluminum makes the problem even harder. There are several threads on this and other forums on this topic. It is desirable to have the leading panel sit slightly proud of the panel behind it to minimize wind noise, which makes sense.
My issue: The bottom of my passenger side front door is proud of the front of the rear door by about 3/32". You can see it if you look at the lines of the truck. It sticks out and doesn't look well aligned. The door aligns better at the top of the panel. After reading up on this, I loosened the striker and tapped it inward with a wood block and mallet, and then tightened it up again. Now, the alignment is almost perfect in the spot at the bottom where it was not aligned, and the doors are aligned at the top. But the problem is that, due to the shape of the stamping, the long edge of the center section of the door now sits "lower" than the adjacent edge on the rear door. Everything looks great, but I'm wondering if I opened up a can of worms and will now hear more wind noise.
How does everyone else's alignment look (does anyone else have doors where the front one is "lower" than the rear in parts?), and do you have wind noise? Also, is there anyone more experienced than me who might have any ideas how to solve this?
