I competed this mod today on my 2021 F150 XLT Powerboost. My truck was already set with a 0 based on the information from the original author of this thread. I need to use the following to disable on my truck.
ACM 727-01-01 xxxx x0xx xxxx
I also changed fog light setting so that they stay on whether using low or high beams and changed the key removal function so the truck horn does not honk if you remove the keys while running.
Hope this is helpful.
Update: I did see DMACs posting where he used this and it impacted sound system. I will need to check that......
