Digitized audio from speakers
PFXLT
AA Ron
Idaho
Hey there y’all.
when I drive around for any longer than, let’s say, 30 minutes; music on and sounds great. I hit the volume but on the steering wheel either up or down and for the split second the screen shows the volume level my music gets “digitized”. Same thing happens when after driving for a while and I put it in reverse to back into a spot or the driveway. I get the same quick burst of digitized audio. Really it seems like any change to the screen after it’s been “idle” for a while causes this.
I do have a JL amp where the audio is being fed directly from the front speaker channels. I also have the JL C2-650 component setup for the front doors and tweeters. Rear doors are stock cause I don’t ride back there. Haha
sorry for the long post, just not sure how else to describe what’s happening.
Common issue with B&O system but this is first I've seen with aftermarket components.
PFXLT
AA Ron
Idaho
I should’ve added it’s the peasant 7 speaker.
maybe an ota will fix it.
Don't know, the only update that I'm aware of is the DSP on the B&O systems. It fixed static/loud pop for me but I still get the digital noise like you mentioned every time my camera turns on.
Chili
Mn
2022 F150
Mine was doing that on the same system. It just stopped randomly. Same XLT 7 speaker system, no B&O. Seemed to only do it with Android Auto. Do you also have a Samsung Galaxy S? I have an s20 plus and others with Galaxy S were reporting the same.
Oh, do you have your sync screen set to always dark? It was reported by some that for some weird reason setting it to dark mode full time fixed issues.
PFXLT
AA Ron
Idaho
I’ll have to try this. Thanks for the tip
PFXLT
AA Ron
Idaho
No iPhone 12 connected via Bluetooth. Also does it while plugged in and using carplay
