Kodiak
I am thinking of getting of this cover with a Front Runner rack/rail system. However I have not been able to get a clear answer to a question. Maybe someone here with this setup can answer.
I need to fold the covers (at least the tailgate cover) over so it lays flat on the other sections. I cannot find out if the T tracks/rails prevent this from happening. I think there may be enough clearance for one rail but not 2 (both front panel and back panel) if they fold over on themselves, but I could be wrong. I believe as long as there is enough clearance for one I could offset the T slot rails on the front panel from the back panel. Then they would nest side by side and not on top of each other when a panel is folded over flat. This would let me need just enough clearance for the height of one rail to have the panel lay flat.
I contacted Diamond Back but they were not really able to answer this. I thought it would be as easy as just taking a Front Runner rail and sticking it in between a DB with the panel folded flat to see if there is clearance for one rail, but I could never get them to do that and answer me.
Also I know that you cannot fold it flat with the rack system attached I just speaking about the T track that you must attach (drill) into the cover. I will remove the rack from the T track if I need to flip the panel flat for some open bed space.
I figure there must be someone here that can answer this as after about a dozen youtube vids I cannot find anyone that shows/speaks to this.
Thanks in advance for any help.
