curious how to turn the plug in the bed on
ollard457
Montana
2022 F150 Lariat
US Army
I have a 23 xlt and I’m curious how to turn the plug in the bed on?
There’s no button on the dash like I’ve seen in YouTube videos and when I go to setting in my main screen o don’t see anything either any help would be appreciated
Kanuck
Winnipeg, Manitoba
Retired Electrician
Start the truck....has to be running if you only have the 400 watt inverter.
Truck needs to be running for the inverter to be powered on.
Walter Townsend
Walter
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
You do not mention which engine set up you have or which version of the ProPower it has. Power Boost runs with engine off, but the ICE ProPower requires the engine to be running in order for the plugs to be energized. Bear in mind that the ProPower 2K is definitely anemic. A mitre saw rated at 15Amps is 1800 watts, but will barely start on the 2K ProPower.
