Cruise control and speed limit signs
JRonchetto
Jim
Missouri
2021 F-150 XLT 302A
My 2021 302A has a problem that has been bugging me since I bought this truck used almost 2 years ago. I had been using the cruise control option of adjusting the setting to match the speed limit. There is this one bridge over a major highway that has a load limit sign of 60 tons. Every time I cross that bridge, the truck reads that sign as the speed limit and slows me down to 60mph. Is anyone else having that issue? Is there a fix? Rugedraw checked my VIN for updates needed today and in the list is Image processing module A. Would that update fix the issue? Thanks.
whizkidder
Ron
Georgia
2022 F150 502
ACC uses both the camera and GPS data to set the speed limit (called fusion in Forscan settings). I I believe you can also select one or the other. Using GPS only might solve your bridge sign problem, but might introduce other issues in areas where the GPS speed data is not current.
