Costco Interstate H8 Battery
Ghurst
Indiana
21 f150 3.5 eco boost king ranch, 601a
Carpenter
Just curious if anyone that’s installed this battery has had any issues. I put in back in march and everything’s been fine till Friday night. Sat morning my auto start/stop ceased to function. The truck is driven every day, around 350 miles per week. One of our wonderful members here just checked for me and my battery is at 68%. Nothing extra on truck to create extra draw (no dash cam, no stereo upgrades, nothing but the lock on my tonneau being tied into the door locks).
Thanks
Aonarch
North GA / MT
'24 V8 XLT 302a BAP, Tow | '22 Mustang Mach 1 | '25 Wrangler JLUR
Motorsport Engineer
Batteries are made by only a few companies (Clarios, East Penn, etc), then the retailer's sticker is slapped on it along with the retailers warranty.
So this has nothing to do with Costco, sounds like you might just have a bad battery.
Get it replaced.
Buyer2021
central TX
retired!
Though many retailers sell batteries made by few manufacturers, the retailer price and warranty terms can vary widely (for the 'same' underlying battery).
Yep, 'stuff happen' to individual batteries. Recognizing that, IMO it's important to carefully shop in consideration of both price and warranty. For any given warranty term, IMO it's worth paying a bit more for a "free replacement" warranty vs a 'pro-rated cost replacement warranty'.
FWIW the one time I used the "free replacement" warranty on a Walmart Everstart Platinum battery (I've owned many of them), the swap was quick and easy with no questions asked and no $ out-of-pocket. That was a battery I probably ruined, inadvertently allowing it to become totally discharged on several occasions in a rarely-driven backup vehicle I own (failed to keep-up with battery-tending).
Parthery
Brian
Atlanta
2023 F150 Lariat 3.5
Costco is straightforward with the exchange as well although they do refund the core credit and then charge it again. It zeros out but ends up being 2 transactions. Not a big deal.
Ghurst
Ghurst
Indiana
Carpenter
You may have just gotten a bad one. Back to Costco and swap it which they will do no questions asked for the first 36 months from purchase.
That’s my guess. I’m going to recharge it and reset the bms and monitor it for a bit first. If it loses charge again…. Off to Costco!
Ghurst
Ghurst
Indiana
Carpenter
Get it replaced.
Not knocking the Costco Interstate at all…. I was just being specific in the battery I have.
Je1279
Jared
Upstate NY
I wouldn't reset the BMS as that makes the system think the battery is new. I would definitely recharge the battery and and continue to monitor it however.
2Lazy2P
PNW
Il Dolce Far Niente
I have a 3-week old Costco H7 Interstate. I just drove 30 miles over a 2-day span. I attached a NOCO 5A tender on the battery. The NOCO showed the battery charge level @ 25%. Should I assume it's a bad battery?
Eighthtry
Boyd
Heath, TX
2021 Lariat SuperCab 5.0
My experience with a H8 AGM in my 2006 F150 was interesting. I think it was a DieHard. My previous conventional battery did well with my infrequent usage of the truck. Same usage and new AGM did not fare as well. I was constantly jump starting after 3-4 weeks or so of sitting. If I drove it any distance it would charge up, hold a charge just fine for 1-2 weeks. It was that long interval that was getting me. Battery survived a load test, so I was not seeing a problem there. Starter in good shape. I could not see any parasitic losses. I chalked it up to that is just the way AGM's are built.
I will buy another AGM for my 21 5.0 as it is now my primary transportation. Sold my Z06/07 and Cadillac CTS V.
Did you charge it before you installed it? My experience is that most batteries need a charge coming off of the shelf. You can use a conventional starter or trickle charger. Trickle will take a little longer.
I also suggest you pay attention to the date of manufacture.
Eighthtry
Boyd
Heath, TX
I just noticed your tender was 5A. I will direct the question to some other experts. Is that too much A for a tender? I use 1.5 and 2 amps.
