Clunk on passenger side when hitting potholes or dips in road.
Ford Motor Company
Official Ford Account
Ford
Dearborn
I have the same noise, did you end up finding a solution to this? I have replaced sway bar links and noise is still present.
Hi there – send a message to us with your VIN and approximate mileage, along with some more details about your situation. I’ll look into this for you. Thanks!
Porpoise Hork
Bret
IT Sys Admin
Check the upper control arm, I found mine was not torqued properly after a level kit install, and it was sliding front to back just a tiny bit as it went up and down. It would make a clunk every time it hit end of travel front to back.
Interesting. Have to check this as mine has the same clunk from the front passenger side.
empty wallet
mike
missouri
2020 ford edge titanium awd, 2010 f-150 4x4,
retired aircraft mech.
splash shield under engine; will have dealer secure or remove and relocate it to the nearest dumpster on first oil change.......2022 K/R
