Caster/Camber Kit for 2021
Crashr30
Will
DFW
2021 Ford F150 XLT
I did a 1.5" lift on the front of my XLT. I still need to get it aligned but I was looking for the Caster/Camber Kit to install on the lower control arm bolts. I cannot find anything for 2021. Does anyone know if the 2020 kit works on the 2021? From the many similarities between 2020 and 2021 I would assume so but I don't really know. If you know of a 2021 specific kit please let me know.
The 1.5" lift did not level the truck and knew it wouldn't as I still like a little bit of rake but it did make the truck look a lot better after switching to larger tires and wheels.
Thanks
KartRacer25
Richard
San Diego
Good question. I'm not sure but 4wheel parts sales guy said he would put in cam bolts or something to lock the alignment in vs stock after we do a Fox level. $120 (seems steep) Haven't done it yet, but they might know what a '21 needs.
Doyouevenboost
Brian
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Ford calls for the “cam bolt kit 3C333”, which is the same kit as the previous years.
On a side note, I installed a two inch level, and my caster/camber was still within oem specs.
Crashr30
Will
DFW
2021 Ford F150 XLT
Good to know, Thank You for the information. It would be nice if the camber/caster stayed within spec. I hope so. Toe and go would make for a short visit to the dealer.
AutonomousHybridF150
Kristopher
Pensacola Fl
2021 F150 Powerboost
Adjuster
Thanks
Would you please post pictures. Would love to see it.
