From the factory you will not have cam bolts, just normal bolts in slots. Adjustments can be made with the stock bolts but it isn't ideal; the adjustments will not be precise, and I wouldn't expect anyone to get the caster and camber set perfectly.
I normally use the SPC 86250 or Moog K100025 cam nut kits to make the adjustments more precise and easier.
