Jerome10
- Joined
- Jun 1, 2023
- Threads
- 59
- Messages
- 528
- Reaction score
- 216
- Location
- North Idaho
- Vehicles
- Powerboost
- Thread starter
- #1
Still trying to pinpoint what sounds like a heat shield rattle around 1800rpm and light to moderate throttle. Sometimes I think it sounds like near the exhaust and others like it’s in the engine compartment.
Listening at idle today I’m hearing a metallic rattle towards the engine area. I’m assuming this is likely wastegate related.
Then on an incline I kept the truck in a high gear in manual mode and applied throttle. Boost gauge showed positive boost to engine, but I could still hear that metallic rattle around 1800 rpm (again not sure if engine or exhaust area).
My limited understanding of the wastegate function is that if the truck is providing boost that the waste gates should be completely closed, correct? And if completely closed there wouldn’t be any slack or slop that could rattle?
or is it possible that even under boost you can get wastegate rattle? Or actuator rattle?
I’ve asked dealer to look twice and been told it’s wastegate. I’m very skeptical that’s the issue so hoping if I can narrow things down I can say “it’s the resonator or heat exchanger” or i can accept that I do actually have wastegate rattle, even as awful and can of marbles as it sounds… and that it’s “normal” to sound like junk.
edit: don’t think it’s bell housing, which has a TSB for other engines but excludes powerboost
