Bug Deflector Journey
Briansk12
Brian
2021 F-150 PowerBoost
Thought I would post to help you guys with decisions if you are looking at or planning on installing some sort of hood protector/bug deflector. I went down a rabbit hole trying to find one that will look good but not mess up the hood.
Started with the Ford bug deflector that sits off the hood. Liked it but it made wind noise so took it off. Mounting hardware is good.
Next was the Aeroskin II. Liked it and had it on for a couple of months. Took it off because it did weird things with the air going through my vents. On windy days the it was like someone was turning my fan from low to high over and over. When I took it off there were already some small scratches in the paint from the edge of the protector. I was able to buff most out.
Next up was the Bugflector II. Fit was terrible. Holes did not line up to mount it correctly. Gave up when it cracked trying to line the holes up.
I then tried the Aeroskin. These are nice but at the end of the day couldn’t stop thinking about the scratches the Aeroskin II made so took it of. Sure enough, more scratches in the short month it was on. Also these ship in a box that was usually crushed by time I received it. AutoVentshade was good and sent new ones but it was a pain. The third one finally came undamaged.
I am finally down to my final decision. Either nothing or the EGR Supershield. By far the EGR is the best. Mounts like the Ford oem using the same hardware. It does not make noise and is a touch smaller. It is solid and out of them all I think this is the best made. Attached are some pics of it in case you haven’t seen it.
Hopefully this helps someone that is thinking about these.
Ford F-150 Bug Deflector Journey F7471C60-C90E-4F5F-8B25-B104F1F0E8DC
Ford F-150 Bug Deflector Journey 7B504FC3-4876-4A4E-B68A-35DBADE98306
Mo21F150
Mohammed
Vacaville
2021 Ford F-150 XLT
Superintendent Bags On / HVAC & Plumbing
Part number or Link?
been trying to nail down a deflector!
thanks I’m advance!
Midwesty
Missouri
2023 F150
Operator
Thanks for the right up! Very helpful. I’ve always used bug shields to help rock chips on the hoods leading edge. My commute is terrible for that.
I have a weathertech on my f250 that works well. My issue is the rubbing on the paint where it wraps around for mounting.
Are you still happy with the EGR brand? Any issues yet, like paint rubbing?
I tried the stick on aeroshield 2, and took it off quickly. The hvac blower pulsating was very annoying. I liked the look though.
PBXL
Somewhere
2021 F150 XL Powerboost
Thanks for the post. I picked up an EGR from American Trucks for about $65 shipped based on your experiences.
in_venere_veritas
Kc
Atlanta
2023 STX SuperCrew 3.5L, 2024 BMW M240i
I took off my Aeroskin as well. If I was ever parked outside in the sun, it would start to lift off at the contours of the hood. Jesus it was a pain to take off. Got my EGR deflector on its way thanks to this thread.
Kodiak
I picked up my 2022 Lariat on Dec 2022 and started looking for a bug/rock deflector immediately. I have the BAP/Tremor style hood and my journey has continued to this day. No soup for us BAP/Tremor hood guys. :(
DadBald
James
2021 F-150 XLT Powerboost
Energy Engineer
Thinking about going with the EGR per the recommendation here. I'm seeing some reviews about misaligned holes even on the EGR from other users, but seems generally well-liked.
I had a stand-off version like the EGR on an old Jeep Grand Cherokee of mine for 10 years. Eventually a bolt came out, it vibrated and broke so I took it off. The clip on the edge of the hood really screwed up the paint, see attached. I really don't want this again!
I also don't like the reports of scratches from the stick on types (many reviews not just here). It seems to be from 2 things: sharp unfinished edges, and debris underneath from non-continuous adhesive strips. You could probably fix the first issue by sanding down the edges to make it smooth, but not the second. So I'm leaning towards the stand-off type.
Maybe my leason-learned on the stand-off type is to check the bolts are tight periodically. I'm also concerned about the longevity of the anti-abrasive tape you put under the hood clips. Maybe a combo of filing the edges of the clips (if they're not smooth) and replacing the tape guard every couple of years would be a good belt and suspenders approach.
Does this seem viable to those who have this type of hood protector?
Ford F-150 Bug Deflector Journey 31927969470_68b94a2093_k
in_venere_veritas
Kc
Atlanta
I think a periodic visual inspection of the clips and anti abrasion strips would suffice. What happened in that photo didn't happen overnight. Looks like it was metal on paint for a while.
Tall Tail
Southern California
2022 F150 SuperCrew XLT 302A 4x4 5.0L 3.31
Did any of these stop rocks from hitting the windshield?
Tall Tail
Southern California
Thanks. There must be a reason that there are over four different threads on the same topic.
Do you have one?
If so, which one?
Are rocks still hitting your windshield?
Have you have any windshield damage from rocks?
Are you experiencing any of this issues mentioned in the OP?
roadPilot
SE Michigan
Do you have one?
If so, which one?
Yes, I *have* one. The rest of the answers can be found in one of the *four different threads* you mentioned. :)
The reason that there are four different threads on the exact same topic is easy: Too many people do not use the SEARCH function before asking a question that has been asked and answered.
akoza
us
'21 XLT 5.0
After a few paint chips on the leading edge of the hood and a rock into the windshield I went ahead and installed the Aero II. More importantly, it's protected the leading edge of my hood, I've had no more rocks hitting the windshield, and the amount of bug splatter has reduced tremendously.
