Boost oscillating under normal driving
fordguy1997
Ryan
Johnstown, PA
2022 F150 and 1997 F250
Hello all,
I have a 2022 with the 3.5 Ecoboost (55,000miles) that is having boost oscillation issues. I attached a video of what it is doing, it’s not the best video but it was all I could get. A lot of times it is significantly worse than the video shows so much so that it feels like you’re stepping on and off the throttle. It will only do this under light acceleration going up a hill, then once you crest the top and some load is let off the motor it will do this. If you give it any throttle or let off at all it will immediately stop. If you put it in any other driving mode it won’t do it at all.
I have brought the truck to the dealer twice for the issue now and has been there a total of two months. I’ve test drove with techs to collect data multiple times. They continue to say there’s nothing wrong and we can’t find anything. I was persistent that there was a problem and they reluctantly agreed to try to change the boost pressure relief valve which as you might guess did nothing. At this point they are essentially refusing to do anything and I have had little to no luck contacting Ford themselves.
I’m hoping someone has had this issue or has any ideas because I’ve had it with the dealer. I would like this to be fixed before my power train warranty is up.
Thanks
Gutshot
Matt
2022 XLT screw
Aggregate junkie
I had the same issue, twice, at 12,000 miles and again a few thousand later. Same scenario too, uphill, freeway speed, fluttered for about 5-10 seconds. Had it in the dealer for some recall work and they couldn’t replicate it, haven’t had it happen since, I’m currently at 28,000.
fordguy1997
Ryan
Johnstown, PA
Mine has been steadily getting worse and more frequent over the last ~5000miles
Gutshot
Matt
2022 XLT screw
Aggregate junkie
I was running 87 when mine occurred, but, it stopped while I was still running 87. I now run 93. OP please keep us posted on how things progress.
DreamcastERA
James
2022 F150 King Ranch - 3.5 EcoBoost
Did anything ever come of this? I have also been getting this behavior recently (in those same conditions) but I am running racing cats and downpipes. Interesting to see it also happens stock at times.
