Mosey
I have now upgraded my speakers, added. Kicker Key 200.4 amp. I wanted a little more base to I added block off plates and sound deadening mat to all four doors.
When I ran the Key audio setup the eq settings really changed and now I have two much base for my taste. I have a few options, turn down the base using the head unit, or use the crossover setting and add a sub. If I were to add a sub I don’t want to spend a load of money and would go with a powered unit.
Is there a way to get the Key to recalibrate but with a less base? Or should use the crossover settings of the Key and buy a sub?
PS - The system sounded great with the block off plates and sound deadening mat installed but the Key calibrated prior to adding them.
