mj1angier
- First Name
- Mickey
- Joined
- Aug 24, 2021
- Threads
- 4
- Messages
- 87
- Reaction score
- 80
- Location
- North Carolina
- Vehicles
- 2021 F150 King Ranch Power Boost
Camera to see if kids are stealing gas, lol
I’d be cautious making statements generalizing from Ford Performance vehicles to baseline Ford vehicles. Unless there is actual Ford-backed documentation or facts, the probability of there being a mileage-induced ECU tune is way way way lower than the other way around.There is a definite change in tune that are mileage driven, but its usually to get better performance not worse as limits were changed in my Focus RS which is also an ecoboost when it reached the end of the break-in
Winter blend fuel uses more ethanol than summer blend and while some stations add a nominal amount, others are known to mix in the maximum allowed. Especially when oil prices are high.
Ethanol has a much lower energy density than gasoline and when combined with gasoline, there's a net decrease in total energy. Meaning that the combined energy of the blended fuel is less than that in the two components before they're added to each other.
Another possibility is a bad O2 sensor, which can result in extra fuel injected. It won't trip any codes unless it's really bad but hopefully the dealer ruled that out, since it can be checked with even a cheap OBD computer.
It's because of two separate but related factors, evaporative emissions of the gasoline just sitting in fuel tanks and vapor pressure during combustion inside the engine. The added ethanol in winter isn't really for any benefit other than they can get away with adding more in during cooler weather, however; at a certain point it won't vaporize at all. Gasoline has a lower range of volatility, so in very cold parts of the country they add more to the E85 so engines can start. In summer, alcohol evaporates more quickly, so they can't add as much because it will cause pollution. When ethanol is blended with the other hydrocarbons in the fuel, it doesn't just evaporate out of solution; it helps all the more volatile strands of hydrocarbons evaporate too.this doesn't really make sense in comparison to winter blended E85. In the winter, E85 has more regular fuel mixed with it due to colder weather conditions for easier start up. Why would they do the opposite for "winter blended" (never heard of a winter blended gasoline, just E85) regular fuel and mix more Ethanol in?
The EPA dictates additional ethanol in winter months for most urban areas.this doesn't really make sense in comparison to winter blended E85. In the winter, E85 has more regular fuel mixed with it due to colder weather conditions for easier start up. Why would they do the opposite for "winter blended" (never heard of a winter blended gasoline, just E85) regular fuel and mix more Ethanol in?
