BAK Revolver X4s Cover Install
rec
Rob
FL
2023 F-150 PowerBoost, 2005 F-150
Has anyone else seen this before? All of the install pics/references I have found show that the edge of the cover appears to be flush with the rails at the tailgate. Seems like these might be a little long?
Ford F-150 BAK Revolver X4s Cover Install IMG_6302
Ford F-150 BAK Revolver X4s Cover Install IMG_6303
Moe7
OH
2022 Tremor
That's about where mine is (cracked part replaced) -
Ford F-150 BAK Revolver X4s Cover Install 1689263304905
TJSparky
WA
Ya, I took a sawza to the left rear corner to make it flush. Not sure if there is a QC problem with the left rear corner in mfg.
rec
Rob
FL
That looks like the opposite problem, maybe (cover extending a bit further than the rails). Maybe the QC is off in manufacturing.
rec
Rob
FL
Mine looks even on both sides (consistently longer than the cover).
rec
Rob
FL
All the installs I seem to find look pretty flush, like this one.
Ford F-150 BAK Revolver X4s Cover Install BAK install
Moe7
OH
2022 Tremor
Ah I misunderstood what you were pointing out. I eyeballed the straight portion of the trim piece to end at the rail, with the radius extending past. The perspective is a bit off in this picture, but if I remember right I also still have some adjustability.
TJSparky
WA
Mine on the left rear side looked liked this as well. Right side was perfect.
Ford F-150 BAK Revolver X4s Cover Install 1689267746888
Moe7
OH
2022 Tremor
I just took another look and mine are pretty close to even. I think that previous picture was when I was first installing it months back.
Ford F-150 BAK Revolver X4s Cover Install 20230713_170914
Ford F-150 BAK Revolver X4s Cover Install 20230713_170907
rec
Rob
FL
Yeah, that looks like what I am expecting. Is yours lined up like this, too (blue arrow)?
I'm getting 67 11/32" on the rail length measurement.
Ford F-150 BAK Revolver X4s Cover Install IMG_6309
Do you have a liner? If it's spray-in, did you remove the pads on the front of the rails where it meets the front of the bed? They aren't very thick, so it won't pull it in enough to eat up all of the length but it might take it in a little.
Thanks!
Moe7
OH
2022 Tremor
Lined up at the front and exact same length on both sides, 67 11/32. I do have a fairly thick Line X, it caused problems with my Builtright bulkhead rail, but I left on the tonneau rail pads (assuming the picture is what you're talking about).
Ford F-150 BAK Revolver X4s Cover Install 20230713_180131
Ford F-150 BAK Revolver X4s Cover Install 20230713_180738
Ford F-150 BAK Revolver X4s Cover Install 20230713_180940
Moe7
OH
2022 Tremor
This might be the difference, my cover length is right at 67 15/32. I'm sure there's a few 32nd tolerance/adjustment there as I eyeballed it when installing.
Ford F-150 BAK Revolver X4s Cover Install 20230713_181550
rec
Rob
FL
I mis
I missed the additional pics in the previous post somehow, but thank you - very helpful for reference. I went out earlier and attempted to reinstall it to see if I missed anything, but didn't notice anything different. The difference in symmetry will stand out to me.
Here's some additional pics. Looks like there might be some difference in the cover lengths.
Ford F-150 BAK Revolver X4s Cover Install under rail
Ford F-150 BAK Revolver X4s Cover Install top rail
Ford F-150 BAK Revolver X4s Cover Install extension
Ford F-150 BAK Revolver X4s Cover Install length with seal
Ford F-150 BAK Revolver X4s Cover Install cover length without seal
