Hanger51
I had a factory speaker go bad in the back door. I ended up put them same kicker ks in all the way around it made quite a improvement.I've read just about every thread there is to on speaker upgrades for the F150 Gen13/Gen14 but am having a hard time finding a concensus on what to do next.
I currently have 2x blown rear speakers on a '21 F150 SCREW Lariat, B&O 8 Speaker (non-unleashed). Rather than replace with the same factory paper cone garbage I'd like to replace with something that will perform a little better (more mid bass, more clarity, more output from the rear).
At this time I don't have any interest in external DSP / Amps, and don't plan to upgade in the future. I think with high-sensitivity / efficiency speakers the 640 watts that the B&O Amp has should be enough for what I'm after (assuming ~35-50W per channel), and using FORScan to output a flat response should help some too. I'd like to spend under $1k for replacing all the speakers except the sub including door baffle panels and some sound deadening material.
Options that I'm considering
Rear Doors:
Coaxial 2-way
Kicker KS 6.5" or 6.75"
JL C2 6.5" (note: C3 doesn't seem to come in a 6.5" two-way, and I don't want to drill a hole for an external tweeter in the rear)
Front Doors:
Component 2-way with Tweeter installed in the A pillars
Kicker KS 6x9 or 6.5" or 6.75"
JL C3 6.5"
I'd ruled out the JL C2 6x9 3-way or the JL C1 6x9 2-way / 3-way because I thoght there'd be too much tweeter presence in the fronts.
Tweeters:
1" from front speaker sets - goal is to keep the existing trim and looks like I can make this happen with a modular / convertable tweeter like the JL C3
Run off existing harness. Add high-pass filter (use crossover filter, build my own, or the C3 Tweeter alerady has one built in)
Center:
Edit: Seems like my original plan won't work since the speaker is 8 ohm not 4 ohm. I might need to look at the Dayton Audio PS95-8 3-1/2". Althogh the sensitivity is much lower on the JL C2 and it *might* work out, I don't want to damage the factory amp expecting an 8 Ohm speaker.
3.5" Kicker KS or JL C2 Coaxial 2-way
The JL C2 seems to have much lower sensitivity (83 dB) than the other C2/C3 speakrs (90 dB) and the Kicker KS (88 dB). This might not be a bad thing considering how "present" the front is?
Questions:
- Are 6x9 really better / worse than 6.5's? It seems like yes they can output more mid-bass at the cost of distortion. How does this play out in the real world?
- Will 6.75's fit or shold I stick with 6.5's? Some say they're the exact same speaker with different brackets, so should I just stick with 6.5"?
- Does anyone have the harness information for the center 3.5" or 1" Tweeters? I'd like to track down factory connections and Cruthfield isn't a help here.
- Any other sensitive / efficient brands I shold be considering? Infinity Reference? Hertz? Morel? I'm no longer considering Focal's after some reviews that they're very bright / harsh / crisp - I think without a new sub this isn't going to be a good fit.
- Any other experience doing what I'm doing (B&O, stock amp, speaker upgrades) would be great!
Thanks
