Are the Heat Exchanger and Resonator 1 Single Part?
Jerome10
North Idaho
Kinda starting to suspect that I've got a rattle in my resonator. When cold and powerboost fires up and around 1800rpm I get a very metallic sounding rattle from the area below the rear passenger door.
I've seen folks putting in a delete tube but I suspect this is not an option with the powerboost as the heat exchanger and resonator come as one part.
Do I have this correct that if either the heat exchanger or the resonator need to be replaced that the entire thing comes out at 1 single unit / part number?
Goldeneye36
NC
2024 XLT Powerboost
It's a single part. That's why doing a resonator delete isn't easy because then you have to figure out what to do with the coolant lines and wires for the exchanger.
Jerome10
North Idaho
Yeah ok shoot. Thought I had that correct. Sounds so.
Bit surprised it is one giant part.
Goldeneye36
NC
2024 XLT Powerboost
Jerome10
North Idaho
Yeah its crazy to me that there isn't a separation between the resonator and the heat exchanger. You'd think the 2 pieces would be easily separable to that a replacement resonator or heat exchanger wouldn't require replacing everything as 1 unit.
JerseyGlock
Jimmy
New Jersey
2021 Lariat Powerboost
One part number and that's why I didn't do the resonator delete, just in case of warranty replacement.
