kmaximus
- Joined
- Dec 10, 2024
- Threads
- 0
- Messages
- 23
- Reaction score
- 25
- Location
- Lexington SC
- Vehicles
- 2024 F150 Lariat Screw 5.0
the "E" harness came in yesterday...that was the last part I was waiting on. the actual part number I received is RL3T-12A409-BEE. Re-checking Ford Parts shows this to still be the E harness and should have all the connections for the existing stuff, inverter and now bed lights.
for those wondering which harness...using https://parts.ford.com/ and looking up your existing harness part number should show you the accessory connections to match against.
for example:
Part #: RL3Z13A409G <- which matches my "DAD" harness
Usage: 12/18/2023, F150, Crew Cab, Tail lamps - Level 3, Less Lighting Packages, Dearborn Plant Build, Less Mass Movement Sensor, Power Inverter #1
compared to:
Part #: RL3Z13A409E <- matches the "BEE" harness I received
Tail lamps. Lighting Package Level A. Power Inverter #1. Dearborn Electrical Vehicle - Crew Cab.
Not exactly the same wording but further research made me feel confident enough to pull the trigger.
I've verified my Forscan software is up to date and connection works in the truck...checked all the plugs on the new hardware, that's good.
As soon as this winter storm situation passes, I plan to get this done by this weekend. I'll take tons of pics and if I can get good video I'll try. I plan to verify the existing harness and the new one before installing, if I get those pics before completion I'll upload those prior to the full install pics.
for example:
compared to:
