rhcgoat
I also have an EBD harness. Again mine is similar to yours in that I don't have on board scales. You should take a peek at your tail lights and check if you have the black or grey connector.
Assuming yours is grey like mine, I found another 2024 Lariat 502a powerboost that has on board scales and it has the "P" wiring harness. I'm tempted to just buy that but I haven't pulled the trigger yet as I'm already sitting on a "K" harness that I have no use for. If you end up going down that route, be sure to post here for others.
I currently have a 2024 F150 lariat with the following packages/options:
-INCLUDED ON THIS VEHICLE EQUIPMENT GROUP 501A LARIAT SERIES OPTIONAL EQUIPMENT/OTHER -2024 MODEL YEAR STAR WHITE METALLIC TRICOAT 995.00
-3.5L POWERBOOST FULL HYBRID 1,990.00
-HYBRID ELEC 10-SPD AUTO TRANS NO CHARGE
-275/60R20 BSW ALL-TERRAIN 3.73 ELECTRONIC LOCK RR AXLE NO CHARGE
-7400# GVWR PACKAGE
-LARIAT BLACK APPEARANCE PKG 1,000.00
-.20" GLOSS BLACK PAINTED ALUM
-50 STATE EMISSIONS NO CHARGE
-PRO POWER ONBOARD - 7.2KW 750.00
-BLUECRUISE EQUIP: 90DAY TRIAL
-TOW/HAUL PACKAGE 785.00
-.INTEGRATED TRAILER BRAKE CONT .LESS ONBOARDSCALE/SMART HITCH
-FX4 OFF-ROAD PACKAGE 1,095.00
-.SKID PLATES
-.LINER-TRAY STYLE-NO CARPET MA
-STANDARD FUEL TANK
My truck (with RL3Z-13A409-H harness) lacks the bed utility package. I tried adding the bed lights, but encountered issues similar to those discussed by you and @nthads. Specifically, the K-version harness (which I purchased) had incompatible taillight connectors, causing blind spot sensor errors. I'm looking for confirmation on the correct harness (specifically, if the P-version is the right one).
