Anyone familiar with this splash screen?
2022Bruce_L
2022Bruce_L
Summerville, SC
2022 F150 XL RCSB
I'm pretty sure I threw up a little. Why in the hell did ya butcher your screen?
Not following ya. It's a 12" screen running the unreal engine update. Went back to previous interface since.
I think the audio portion of physical buttons could go away, but not climate. Trust me -- I absolutely HATE the climate stuff of the 15.5" screen. It's trash, it's glitchy, it's dangerous. If the screen glitches, goodbye climate control and everything else w/ out a button. This is exacerbated on the MME as the bottom of the screen is pretty low, roughly where the right knee is even with legs out more than down being the seats aren't tall (mid img)
As for the 12" screen, the top bar could be done away with and the gap at the bottom between screen buttons and AA's area removed -- remove icons from bottom and just have the text buying more space, vents reconfigured and enlarge to a 14". There's no replacement for being able to blindly reach out for climate to adjust temp and fan. I need to make a vid of someone other than me fiddling with the 15.5" screen showing how dangerous it is to be dicking around with the slow / glitchy / poorly laid out functionality.
This is closer to perfection than the MME! The big deal is spring / fall when there's 35 degree differences in temp. Being able to blindly reach temp / fan speed are important.
Ford F-150 Anyone familiar with this splash screen? 1691712269017
Looking that far down just to screw with climate is dangerous and annoying.
Ford F-150 Anyone familiar with this splash screen? 1691712897383
and the portrait screen is very poorly laid out. To turn off reciculation which always defaults on w/ AC, it requires a button press to bring up another layout, then its little 1/2" button needs pushed. When the vehicle is in reverse, can't control which vents are alive or recirc either. Put the car into neutral or park to adjust some values in the AC. It's just a really bad design -- also can't use cruise control in it with the hand at 11-1 oclock position otherwise the DE-EYE nanny goes naughtzeee. These are the types of nonsense issues that we have to deal with for the same reason that little titan submersible imploded. Don't listen to those 40+ men.....
Ford F-150 Anyone familiar with this splash screen? 1691713127741
hotrodmex
Ca
22 Lariat 500.5a
The Unreal rendering and Climate Bar are two different modifications. I have the Unreal rendering enabled, but I did not want the climate bar.
People conflate them often here. General symptom of people saying "tell me what to change" rather than "what am I actually changing?"
2022Bruce_L
2022Bruce_L
Summerville, SC
2022 F150 XL RCSB
I ended up enabling unreal as well as climate bar. Figured out had to enable mirroring as well to get the fan speed and temp controls to work on the graphic.
timnohio
Tim
2024 Ford F150
Saw this on IG and was curious if anyone knew anything about it. Pretty sure I had managed to try out all the various one in Forscan so thinking it may be custom.
How do you change the splash screen on a 2024 using Forscan?
I haven't seen how to change it.
BPX Elite
Brett
2025 F150 5.0 RCSB
Using the forscan software its listed under the APIM settings. However, i have a 2025 RCSB with the XL trim and i cant get any of them to load other then the regular F150 and the Raptor. I really wanted the Ford GT screen but it doesn't load for me.
Did you get it figured out on yours?
timnohio
Tim
2024 Ford F150
No. I gave up on it.
BPX Elite
Brett
2025 F150 5.0 RCSB
Yeah!! Right there with you. All i got to work on my 25 was bambi mode. Guess ford is locking them down. I don't see much of a reason in forscan as this point for the new models.
