ordered mine on 2-16-21, its was built on 3-21-21, got vin and window sticker now truck sitting on dearbourne lot waiting for backup camera according tp dealer.Let's kick off the party for 4/26 Build Week. I ordered 3/11 and got my VIN today. 6 weeks from order to build week seems too good to be true so I'm cautiously optimistic. Let's see what all these chip shortages do
Mine is getting build on 4/27 as well. your rotation number is 2677 (probably day shift) mine is 3324, which is likely afternoon shift..
Mine is same day with 2861 number. I am assuming this is the day it starts? so technically it should finish production 3 days later?Mine is getting build on 4/27 as well. your rotation number is 2677 (probably day shift) mine is 3324, which is likely afternoon shift..
You're only 2 hours behind C Low's unit.....Yes, I believe that when it's "bucked", the beginning of the line in bodyshop. Should be out the door within 24 hours, unless it ends up in the paint repair hole due to damage or bad paint-job, or gets hung up because of a two-tone paint job, which takes extra time.Mine is same day with 2861 number. I am assuming this is the day it starts? so technically it should finish production 3 days later?
Wow, fast turn around timeordered mine on 2-16-21, its was built on 3-21-21, got vin and window sticker now truck sitting on dearbourne lot waiting for backup camera according tp dealer.
I thought I read somewhere that it took 3 days from start to finish in the factory. 24 hours is moving along to completely build a truck. I am just hoping we don't end up in the field waiting on chips for the next 6 months.You're only 2 hours behind C Low's unit.....Yes, I believe that when it's "bucked", the beginning of the line in bodyshop. Should be out the door within 24 hours, unless it ends up in the paint repair hole due to damage or bad paint-job, or gets hung up because of a two-tone paint job, which takes extra time.
That’s what I’m worried about also. Being built then sitting in a lot for parts or a chip.I thought I read somewhere that it took 3 days from start to finish in the factory. 24 hours is moving along to completely build a truck. I am just hoping we don't end up in the field waiting on chips for the next 6 months.
I worked at STAP, where the Crown Victoria and Continental's were made. We build 60/hour. Not positive, but i think they pump out close to 60/hr at Dearborn as well. Took 2.5 shifts from beginning to end, so....20 hours if it kept moving and didn't get hung up in a repair hole along the way. From what i rread, ford has put priority on costumer orders and uses the chips up on them first. I've ordered a Plat without moon roof, no Max trailer. No clue if that had anything to do with the short turn-around for me. I ordered it 3/12I thought I read somewhere that it took 3 days from start to finish in the factory. 24 hours is moving along to completely build a truck. I am just hoping we don't end up in the field waiting on chips for the next 6 months.
Hello,
It was under check my window sticker.Hello,
How did you get this link ? My truck is scheduled for april 27th and status changed to in production yesterday.
Sorry for the delay. But yes that worked for me. I was able to get my window sticker from that link also.I'm from canada and I get an "not a USA vin" when I go on this site.
Could you please check this link if you are able to see your sticker also ?
https://www.f150gen14.com/forum/pages/tracker/
Regards,
Regards,
