Maxzina
Jason
New Jersey
2024 F150 Lariat
Hey F150 Owners! ?️ Upgrade Your Truck with Heavy-Duty Side Rails (2015-2025 Models)!​
? Perfect Fit: Designed for your F150’s bed walls (under the rear toolbox), these aluminum alloy side rails are lightweight, rust-proof, and built to last.
⚙ Ultimate Utility:
L-Track Tie-Down System
with adjustable O-ring tie-down anchors and L-track bolts lets you secure cargo of ANY size or shape.
Spring-loaded anchors lock firmly into the rails—no sliding, even on rough roads!
Versatile options: Hook bungee cords, strap down gear, or loop ties through the rings.
Note: If your truck is equipped with a DIBL (drop-in bed liner), please make sure to cut and reserve the original holes for installation.
Attention:Can only be installed at the screw hole below
? Check out the photos and watch the install video to see how easy it is to transform your truck bed!
? Exclusive 20% OFF for F150 Forum Members!
? LINK: https://www.amazon.com/promocode/A3Q8MYTX2YY41E
? CODE: JBBFGOCH
⏰ DEAL ENDS: June 13, 2025, at 23:59 PST!
? Join Our F150 Crew!
Got questions? Want more truck hacks? Join our Facebook Group to connect with fellow F150 enthusiasts and get insider tips!
#F150 #FordTruck #TruckMods #Overlanding #OffRoad #TruckAccessories #DIYInstall #DealAlert #TruckLife
Kodiak
Looks great! L-Track has a lot of options too.
Any plans on a black version? It is easily paintable but a black option would be a great addition to your lineup if possible.
Good luck!
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Good luck!
Yes. We have a black version of the plan. (y)
basicbetty
Jake
SoCal
'24 502A, 5.0 Whipple, BAP
Electrical Contractor
Nice job, so glad I don't have to DIY this. Waiting for the black option... let us know!
bjl95mustang
Pflugerville Texas
2024 F-150 STX 4X4 2.7
Fire Fighter
What gauge steel is the bracket that attaches the rail to the truck?
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Okay.Of course sure!When it available,I will post it on forum with 20% discount.
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
One moment please. We will measure the approximate thickness for you.
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Lead-Foot
NC
2021 Ford F150
I would think the brackets would fit the upper mounting holes. The problem may be that the L track my not clear the upper bed rail support (jut-outs, see their 1st picture).
I ran into this when I was building my DIY E-track tie down mount and side panel equipment mounts. Ended up with revision #3 to get the mount and rail correct.
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Guess they don't fit in the upper holes?
The upper has a curvature that may not match the rail, as the rail fits snugly against the inner wall.
Maxzina
Maxzina
Jason
New Jersey
2024 F150 Lariat
Yeah.There are protruding parts on the upper level, which prevent the rail from matching with the upper hole position.So great that can be used normally after revision. (y)
