2kW Pro Power with EcoBoost
12Lariat21
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Ran some more test with some power resistors.
10.2 ohms = 1100 watts @ 108.5 Volts 10.4 Amps
6.1 ohms = 1900 watts @ 105 Volts 17.4 Amps seemed to be able to maintain this load, only ran for 4 minutes due to the power resistors getting hot. (images associated with this test)
5.9 ohms = 2000 - 1900 watts @ 104 Volts 17.8-17.9 Amps the inverter tried to power this, but it would fault out on overload after about 5 seconds.
Ford F-150 2kW Pro Power with EcoBoost F150_1900W load
diesel97
rob
Ford Edge
electrical
Loads are rated at 80% continuous just like a house breaker most likely
12Lariat21
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Oh I would totally understand that, and most if not all generator/inverter manufacturers advertise their output as peak, and they list the continuous usage. Ford on the other hand, has seen fit to advertise it at 2kW, 20A at 120V...no less
So it's more a disappointment in their handling/marketing of it.
And honestly it's a pretty crappy inverter to drop 16v at load, for the $995 MSRP they charge for it.
To me it's kind of like Dyno numbers.
For me that's what they are. Numbers.
I just want to be satisfied with how the truck performs on the road. In fact, I'll give some of the numbers back in trade for a more polished or refined experience.
In respect to ProPower Onboard, I purchased the Powerboost to power my RV as if I was on shore power. It passed that test with flying colors. I don't know how much headroom was left, by the numbers, but I'm happy. Especially considering it accomplished the task using one bank. That would indicate that I am free to upgrade to a 50A RV in the future. Although in my opinion, the kind of 50A RV that I would buy isn't a tow option for the Powerboost. (yet more numbers. In this case, Cargo Capacity lol)
diesel97
rob
Ford Edge
electrical
I bet with more RPM's the voltage will be higher. You have to leave some head room so you don't have to high a voltage when going down the road.
The DC voltage of the alternator will fluctuate.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
It would be nice if Ford listed the continuous and peak numbers for ProPower. I'm guessing that whatever is listed is actually the peak based on what some have posted, and run wattage is less. I haven't tested mine like you have, but the voltages you're seeing would be concerning to me.
Bryan
Orlando
2022 F150 Tremor
Offroad Traveler
I'm a little late to the party here, but have been dealing with the same issue on my new Tremor. Using my RVs GoPower 2000W inverter-charger's 30Amp connector and a 30A-to-15A dogbone connected to my 2kW ProPower's "120V/20A" outlet, I can run my RV's Dometic Penguin II to which I added a Micro-Air Easy Start ... but to make this work, I have to set the GoPower inverter-charger remote to draw no more than 9amps shorepower. And while that's not enough to full run the AC from the Pro Power (actually only draws about 950-1000Watts from propower), it draws the additionally needed power from the RV's LiFePO4 battery bank. Anything higher than 9amps for the shore power draw setting causes the inverter-charger to briefly fault. And once the compressor kicks in, I can increase the shore power setting up to about 15-16 amps before tripping the ProPower breaker as it reaches the ProPower inverter's wattage limit. But I can't figure out what the issue is at that 9 to 10 amp limit that causes the system to freak out, except perhaps the voltage drop you measured at higher wattage/current. To your point, disappointing that Ford continues - even more than 2 years after your experiment and comments - to market ProPower with solid concrete numbers.
12Lariat21
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Yeah it's a pretty sad inverter they are using. It's either the voltage drop, or crappy sign wave. I can only assume at about 9amps is where it all starts going down hill. Ok at running resistive loads (toaster, hot plate) not so much when dealing with electronics or motors...
12Lariat21
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Out of shear boredom and curiosity, I decided to pull the covers off all the 2kW pro power setup on my truck this weekend. Attached are the photos for those curious. The inverter is actually a 24v DC to 120 AC inverter, and uses 2 of the smallest little 12v batteries I've seen to feed it...defiantly part of the reason the system is a sub-performer, not a whole lot of power to supply, so any load is going to drag it down quick. I'd like to get extremely bored and hook it up to a couple of real 12v batteries and see how/if it improves its performance any....but that is a lot of messing around I'm not sure I want to tackle
Ford F-150 2kW Pro Power with EcoBoost IMG_1515
Ford F-150 2kW Pro Power with EcoBoost IMG_1519
Ford F-150 2kW Pro Power with EcoBoost IMG_1523
Walter Townsend
Walter
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
Those two little batteries are being used more like capacitors to smooth out the input voltage than batteries as the 2K PPoB only operates if the engine is running and then there is a 24V alternator directly charging the batteries all the time that ProPower is on.
The system is anemic, I would really like to figure a way to upgrade the 24VDC to 120 AC Inverter and they seem to be available in the 3000 Watt range. 6000W peak 24.25A
https://www.bestproductscanada.com/...MIgsiLw-X_hgMVndjCBB0JbwoXEAMYAiAAEgIhuvD_BwE
Anybody done this yet?
lrb_35128
Larry
San Antonio Metro Area
2024 F-150 King Ranch
Does anyone know if the folding storage will work with the 2kw propower? I had heard you couldn't do it on the b&p but I also heard it'll fit
Don't think this ever got answered. (Apologies if it did.)
Short answer, "yes" - My 2024 came from the factory equipped with both.
