2024 XL center console question?
TopOMichXL
Northern Michigan
2019 XL RCSB 4x4 , 14 th gen XL RCSB 4x4 on order
Carpenter/Boatbuilder
I have a 2024 RCSB. I’d like to remove the center console’s headrest. It was easy in 2019 RCSB that I had.
I’ve looked in the supplemental manual, and it says to pull it up, press the button and pull it up/out.
My problem is I can’t get the headrest to budge, I’ve only tried hard enough to avoid damage.
As anyone else removed theirs, and was it difficult? Thanks in advance.
jasonkosi
Jason
Chilliwack
2024 RCSB
The center ones are pretty tight when they’re pushed down all the way, and will lock in that position. You’ll have to get your fingers under it to press the buttons on the retention posts to get it to release.
Rinn69
N Central IOWA
Retired USAF Medic
x2
TopOMichXL
TopOMichXL
Northern Michigan
Thank you very much and I’ll be trying again and check back in.
TopOMichXL
TopOMichXL
Northern Michigan
Thank you gentlemen! Yes, it really was in tight, I’ve always taken them out right away, but this one was tougher than before.
Ford F-150 2024 XL center console question? IMG_2206
